An attempt to delete a VLAN translation range hardware entry on the specified port failed. The reason_string parameter may give additional details on why this occurred.
If the reason_string indicates "Entry not found" and there was a previous occurence of HAL.VLAN.AddVLANXlateRangeFail then this can be normal and no action is required. Otherwise, saving the configuration and rebooting should restore the proper VLAN translation hardware programming.
Error
Failed to delete ingress VLAN translation entry for VLAN IDs %firstVlanId%-%lastVlanId% to vlanid %newVlanId% on port %port% due to %reason_string%
| Name | Type |
| firstVlanId | VLAN-tag |
| lastVlanId | VLAN-tag |
| newVlanId | VLAN-tag |
| port | String |
| reason_string | String |
